Automatic Doorbell with PIR Motion Sensor
Have you ever noticed that when you entered 7E there is a ding dong sound? Or when you enter a toilet, then suddenly the lamp turned on by itself? It’s actually using a Passive Infra-red (PIR) Motion Sensor. A sensor where it detects any heat that occurred to trigger the sensor. Let’s scroll down to get more info.
HARDWARE PREPARATION
This tutorial use :
CONNECTION | |
PIR Sensor : VCC | Maker UNO: 5V |
PIR Sensor : GND | Maker UNO: GND |
PIR Sensor : Out | Maker UNO: pin 5 |
SAMPLE CODE
Thank you
