Automatic Dustbin Using REKA:BIT
- 23 Jun 2021
- 1366
Maybe this is the first tutorial using REKA:BIT. ? So I decide to build a simple automatic dustbin. When the sensor detects an object distance of less than 10cm, the servo motor will open the cover for 5 seconds.
This video shows how automatic dustbin works with REKA:BIT.
- REKA:BIT - Simplifying Robotics with micro:bit
- Grove - Ultrasonic Ranger
- RC Servo Motor (Metal Gear)
- Aluminum 25T Servo Horn Arm (Red)
This sample program is using MakeCode. Before that you need to add the extension of "rekabit" and "grove".
