Build an RC Boat Using micro:bit
- 03 Apr 2023
- 1455
Ready to set sail? Learn how to build your own remote control boat using a micro:bit! Follow along with this easy-to-follow tutorial and you'll be cruising through the water in no time.
- MOTION:BIT - Simplifying Motion Control with micro:bit
- micro:bit V2 mainboard
- 2x 3V Miniature Brush Motor with wire leads
- 2x DIY 4 Blades 56mm Motor Propeller (Blue)
- SG90 Micro Servo
Code #1 - For the first micro:bit on the boat
- Add “MOTIONBIT” extension
- then follow the code block in the picture above
Code #2 - For the second micro:bit to remote control the boat
STL Files to 3D Print the Boat
The boat was 3D printed using Artillery Hornet. You can find the STL files Here
Project Complete
Here's how the project works:
With the remote-control micro:bit, you can:
- Shake it to start the motors
- Press button A to move the fin 130 degrees
- Press button B to move the fin to 50 degrees
- Press both buttons A and B to return the fin to its default position of 90 degrees
- Touch the micro:bit logo to stop the motors from moving.
Now you're ready to take your RC boat out for a spin!
