Build Smart Alarm System Using IoT with micro:bit
- 10 Aug 2022
- 1402
This tutorial will teach us how to build a Smart Alarm System using IoT with microbit. If the IR sensor detects someone is entering the house the microbit will send an alarm notification to your device through Telegram. ⚠️?
- Connect IR sensor to P1
- Follow the steps here to create Telegram bot. Get the API key of the Telegram bot and chat ID.
If you want to learn more on how to send messages to Telegram, please check the video tutorial here - After completing the code, download it on microbit
Project Complete
Upon completing the project successfully, you shall receive a message notification on your Telegram once the IR sensor detects someone entering the house.
