Create an Alarm Clock with micro:bit | Easy for Beginners
- 23 Dec 2022
- 2576
When the micro:bit connects to the internet, the creativity of making amazing projects becomes limitless. One example of these projects is the alarm clock, where the micro:bit will have access to the internet time, therefore, making an alarm becomes handy. Join us in this simple tutorial to learn how to create your own alarm clock using micro:bit.
- Add “ESP8266 Cytron” extension, then follow the code block in the picture above
Project Complete
Press button B for a snooze, or button A to turn off the alarm
