Before this, I have share How to Display on I2C OLED Using Raspberry Pi. So besides OLED, there have another alternative cheap display you can consider. It is I2C LCD. So this tutorial will show you how to display on I2C LCDusing Raspberry Pi.
This video will show you how to display on I2C LCD using Raspberry Pi Zero WH (2018-06-27-raspbian-stretch).
ITEMS USED IN THE VIDEO
- I2C 1602 Serial LCD for Arduino & RPI
- 16GB Micro SD Card with NOOBS for RPI
- 5V 3A Adapter micro B c/w Switch (UK Plug)
Program
This is sample code and library used in the video.
References
