Displaying Real-Time Info on an LCD with micro:bit
- 11 Feb 2023
- 1257
Hi everyone, in this tutorial, we're going to learn how to display real-time information such as date, time, and temperature on an LCD screen using micro:bit. Whether you're a beginner or an experienced programmer, you'll find this project both fun and educational. So grab your micro:bit and let's get started!
- REKA:BIT with micro:bit
- Grove WiFi 8266 – IoT for micro:bit and beyond
- 3V3 I2C and SPI 1602 Serial Character LCD
- For the LCD, connect GND to VSS, 3V3 to VDD, SDA to SDA, SCL to SCK
- Add “ESP8266 Cytron” extension
- Add "micro:bit + LCD" extension using this link: https://github.com/cytrontrainee/microbit-lcm1602-14-lcd-extension
- then follow the code block in the picture above
Project Complete
Now the time, date, and temperature are displayed on your LCD
