DIY Fire Detection and Suppression with Raspberry Pi Pico
- 08 Nov 2023
- 368
Learn how to build a fire detection and suppression system using a Raspberry Pi Pico, a flame sensor, and a water pump in this quick and easy video tutorial. Keep your surroundings safe from fire hazards with this DIY project!
Flame Sensor Module
$0.90 $1.25 $0.90
Micro Submersible Water Pump DC 3V-5V
$0.98 $0.98
Robo Pico wtih Raspberry Pi Pico with Pre-solde...
$21.40 $21.88 $21.40
- Connect the flame sensor GP3
- Connect water pump to motor terminal 1
Project complete
The code runs an infinite loop, checking the flame sensor for fire detection. If a fire is detected, it activates the water pump for 5 seconds and then turns it off.
