Press the Buttons
Press the Buttons
This guide will show you how to set up the buttons on your MOTION 2350 Pro through coding.
The figure below shows the GPIO for each of the on-board push buttons.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this (no lib file is used):
