Getting Started | Using Raspberry Pi Pico W with Blynk
In this tutorial, we'll show you the simple steps to connect your Raspberry Pi Pico W to the Blynk platform, enabling you to create exciting IoT projects effortlessly. Learn how to set up the Pico W, establish a connection with Blynk, and control your devices remotely through a mobile app.
Setup Blynk
  1. go to Blynk website, create a new account, and log in
  2. create a new template
  3. from datastream add a virtual pin
  4. then add a new device
  5. select the template that you have created
  6. from the web dashboard add a switch
  7. now copy the token and let’s start making the code for Pico W
Required Libraries to Build the Code
Unzip the file, and locate these 2 libraries:
- adafruit_requests.mpy
- simpleio.mpy
Copy and paste them into "lib" folder on your CIRCUITPY drive.
Project complete
Now you control your Pico W through Blynk platform. You can also use the application on your phone to do the same thing. All you have to do is to sign-in to your account, click on Pico W device, then from the widget box add a switch to control the GPIO pin.
