Getting Started with MOTION:BIT Pro
- 05 Jun 2024
- 713
MOTION:BIT Pro is an expansion board that is designed to simplify motion control using 12V DC Motor or Servo Motor with micro:bit.
This getting started and projects guide will help you to kick start your MOTION:BIT Pro projects with some simple guides, hardware setup or example codes including:
- MakeCode Extensions and Flashing the Code
- DC Motor
- Micro Servo Motor
- Li-Ion Battery and External Switch
- Maker Ports (qwiic) and GPIO Breakout
- RGB LED and Daisy Chained RGB LED
- Remote Control via Bluetooth using Smartphone
