Getting Started With Sparkfun RedBoard Qwiic
- 17 May 2022
- 1152
In this tutorial we shall see how to get started with Sparkfun RedBoard Qwiic. So what is RedBoard Qwiic? RedBoard Qwiic is an Arduino-compatible development board that uses a few of the features that we have loved about Arduinos of the past while also incorporating a few key improvements over the original RedBoard. The best part about the RedBoard Qwiic is that it utilizes the handy Qwiic Connect System which means no soldering or shields are required to connect it to the rest of the system.
On top of that, there are few additions that make the Sparkfun Redboard Qwiic unique. With the improved AP112 voltage regulator, this RedBoard gains a more robust 3.3V regulator that provides it more power to daisy chain multiple Qwiic boards ans sensors, sourcing up to 600mA current.
The hardware that we will need for this tutorial is the Sparkfun RedBoard Qwiic.
Setting Up The Arduino IDE
The steps to setup the Arduino IDE is as shown in the figure below
- First we open the Arduino IDE.
2. Next we choose the Arduino Uno board.
3. And finally we choose the correct port. In my case the port is COM4
Now we are ready to program our RedBoard
The example we use for this tutorial is the blink example.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
void setup() {
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
Outcome
That's about the tutorial on getting started with Sparkfun RedBoard Qwiic. In the upcoming tutorial we shall how to use the Qwiic.
Thank you.
