How to Make a Light-Following Sunflower Using micro:bit
- 27 Jul 2022
- 803
Sunflowers face the rising sun because the morning warmth attracts more bees and also helps the plants reproduce more efficiently. Let's make a sunflower that reacts to the light level in the surrounding using micro:bit.
- Connect the servo motor to the first servo port
- Add “REKABIT” extension and follow the code block in the picture above
- After completing the code, download it on your micro:bit
Project Complete
Upon completing the project successfully, the servo motor will rotate based on the light level in the surrounding.
