IoT Push Notification Using Rain Sensor with MicroBit
- 27 Oct 2021
- 1422
So many useful applications can be done with the rain/water sensor, in this tutorial, you will learn how to use both of rain sensor and the wifi module to send push notifications to your telegram app.
- Connect the rain sensor to P0
- Add "ESP8266 Cytron" extension and follow the code block in the picture above
- Follow the steps here to create a Telegram bot. Get the API key of the Telegram bot and the chat ID.
If you want to learn more on how to send messages to Telegram, please check the video tutorial here - After completing the code, download it on microbit
Project Complete
Upon completing the project successfully, you shall receive a message notification on your Telegram application when the rain sensor gets wet.
