IRIV PiControl - Remote Control With VNC Viewer
Welcome back to the IRIV PiControl tutorial series, in this part, we'll explore how to remote control your IRIV PiControl using VNC Viewer. We'll walk you through two distinct methods: the Standard setup, involving direct interaction, and the Headless Setup, providing a seamless way to control your Raspberry Pi without the need for a physical display.
Method 1: Standard Setup (Direct Interaction)
Start by connecting IRIV PiControl to your monitor using HDMI cable
At the top right corner, click on the WiFi icon, set WiFi country, then disable WiFi, and then enable it again.
Connect to your network
At the top left corner, click on the Raspberry Pi icon, then open Raspberry Pi Configuration
Under Interfaces section, enable VNC
At the top right corner, click on the VNC Viewer icon. A window will pop up that shows your Raspberry Pi's IP address.
Now, switch to your laptop/PC to remote control your Raspberry Pi. Open VNC Viewer (Download here) and type in the IP address.
Use the following credential to login ..
Username: pi
Password: raspberry
Process done successfully.
Method 2: Headless Setup
Use a USB-C cable designed for data transfer and connect one end to IRIV PiControl and the other end to your laptop or PC.
Open Device Manager and locate the Ports list, after connecting IRIV to your laptop/PC, a new COM port should be detected
Use a terminal software such as Putty (Download here) to connect to this COM port.
for the Connection type, select (Serial)
type in the detected PORT (COM8)
and change the baudrate speed to (115200)
Press Enter, then use the following credential to login ..
Username: pi
Password: raspberry
Now, you are successfully connected to the IRIV PiControl terminal
To proceed and prepare the IRIV to be ready for your use we need to disable Demo Mode and set up WiFi.
Run this command from the console to disable the autorun service for Node-RED:
sudo systemctl disable nodered.service
Run this command to list out the available WiFi network:
sudo nmcli dev wifi list
Use this command to connect to the WiFi network:
sudo nmcli --ask dev wifi connect (SSID)
Replace the (SSID) with your WiFi network name.
Enter the password when prompted.
After IRIV is successfully connected to WiFi, run the following command to open the configuration tool:
sudo raspi-config
Using arrow keys, go to “Interface Options” and press Enter
Enable VNC
VNC is now enabled.
Run this command to view the IP address:
ifconfig
We will use this IP address to control IRIV via VNC Viewer
Username: pi
Password: raspberry
