Microblocks with EDU PICO : DC Motor
In this tutorial page, we wil teach you how to use DC Motor on EDU PICO board using MicroBlocks the block programming language.
What is DC Motor ?
A DC motor is an electrical motor that uses direct current (DC) to produce mechanical force. The most common types rely on magnetic forces produced by currents in the coils. Nearly all types of DC motors have some internal mechanism, either electromechanical or electronic, to periodically change the direction of current in part of the motor.
Lets's start dragging the block.
Step 1 : Drag the blocks
Step 2 : Change the pin value.
Step 3 : Run the blocks.
Click ==> DC Motor
Let's watch the tutorial video
Let's move on to next tutorial!
Related Posts
Microblocks with EDU PICO : CircuitPython Installation
This tutorial will help you on your journey to exploring MicroBlocks with EDU PICO board...
