This is the tutorial to modify the DIY Wooden Robotic Dinosaur (with Batteries) to a remote control DIY Wooden Robotic Dinosaur using the small receiver and the transmitter with anten....
VideoHardware PreparationThis are the list of items used in this tutorial.Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP2040Maker Drive: Simplifying H-Bri....
After assemble the Otto robot, next we will try to program it using CircuitPython. Basically we need to know how to control 4 servo motors to create the robot movement.....
I would like to try building the Otto DIY robot using Maker Nano RP2040 and program it using CircuitPython. But the STL file provided cannot fit the board. So how?....
Raspberry Pi Pico is the 1st Microcontroller Development Board from Raspberry Pi Foundation. It is also based on the 1st Microcontroller IC/Silicon - RP2040, designed and produced by Engineers from th..
In this tutorial, I’ll share with you on how to build a Line Following robot using Arduino and Maker Drive. Before this we’re using an L298N motor driver and now we’re going to chang....
