Interfacing Raspberry Pi Pico With 0.96
- 08 Jun 2022
- 1708
In this tutorial today, we shall see how to interface the Raspberry Pi Pico with 0.96" IPS display and dht22 sensor using the Arduino ide.
For this tutorial we will need the following components
Building The Circuit
The connection between the Raspberry Pi Pico, 0.96" IPS display and DHT22 are as shown below.
Please do note that the Arduino shown in the image above is the classic Arduino Nano. I have this, because there is no library for Maker Nano RP2040 yet inside the Fritzing.
Below is the complete code that we have used in this tutorial
#include // Core graphics library
#include // Hardware-specific library
#include
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22
#define TFT_CS 10
#define TFT_RST 7
#define TFT_DC 9
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
DHT dht(DHTPIN, DHTTYPE);
void setup(void) {
tft.initR(INITR_MINI160x80); //Initializes ST7735.
//Please note that use of 'MINI160x80' displays cyan instead of yellow and vice versa.
dht.begin();
tft.setRotation(3);
tft.fillScreen(ST7735_BLACK);
tft.setCursor(5, 5);
tft.setTextColor(ST7735_RED);
tft.setTextSize(2);
tft.println(" Pi Pico ");
tft.setCursor(5, 25);
tft.setTextColor(ST7735_GREEN);
tft.setTextSize(2);
tft.println(" DHT22 ");
tft.setCursor(5, 45);
tft.setTextColor(ST7735_BLUE);
tft.setTextSize(2);
tft.print("0.96 Display");
delay(2000);
delay(200);
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
tft.setCursor(5, 20);
tft.setTextSize(2);
tft.print("Temp:");
tft.print(t);
tft.print("C");
tft.setCursor(5, 40);
tft.setTextSize(2);
tft.print("Humid:");
tft.print(h);
