PROJECT 2
GRAPHIC LCD DISPLAY
Back to Project 1 | Go to Project 3 |
Arduino Duemilanove have come with a Graphic LCD shield which allow allow user to play with more pixel besides LCD. This shield have 48×84 pixel resolution. If your project need more information to display, this LCD shield can apparently meet your needs. It is able to display English, Chinese, even images.
COMPONENT NEEDED
ARDUINO -GRAPHIC LCD SHIELD |
CONNECTION
Referring to the Figure above, the GLCD are only required to plug into Arduino Duemilanove then put in the coding, the shield are ready to display.
ADDITIONAL INFORMATION
For Arduino- GLD shield, It also integrates a 5 DOF joystick. The shield has 6 Digital IO and 5 Analog IO. Besides that, we may control the backlight by just use digitalWrite(7, HIGH/LOW) to turn it on and off. Don’t forget to put pinMode(7, OUTPUT) in void setup();.
Well, reading the joystick position is accomplished via analogRead(0);. It returns the following values as such:
- Up – 505
- Down – 0
- Left – 740
- Right – 330
- pressed in – 144
- Idle (no action) – 1023
CODE OVERVIEW
int adc_key_in;
Define the adc_key_in as a storage space of integer.
int joy_stick = 0;
Define the joy_stick I/O as analog port 0.
int adc_key_val[5] = {50,200,400,600,800};
Initial the joy stick ADC value.
#define LCD_Backlight 7
Define the LCD_Backlight pin as ditial pin 7.
#define NUM_KEYS 5
Define the total number of key is 5.
lcd.LCD_init();
Graphic LCD Initialize.
Lcd.LCD_clear();
Clear the GLCD screen.
pinMode(LCD_Backlight, OUTPUT);
Make the LCD_Backlight pin as output.
lcd.LCD_draw_bmp_pixel(2,1,cytron,80,24);
Display the picture in Bitmap format in (2nd row, 1st column, cytron logo, picture’s width, picture’s height).
lcd.LCD_write_string(0,a,“01234567890123”,MENU_NORMAL);
Write a string of number in every row.
lcd.LCD_write_string_big(0,0,“012345”,MENU_NORMAL);
Write a string of number in big font size.
