PROJECT 8
PIEZO BUZZER: MELODY – BIRTHDAY SONG
Back to Project 7 | Go to Project 9 |
Piezo buzzer, generally use as a sensor and actuator which are use to measure force, pressure , tools for positioning object and etc. As for this project, we are going to use it to generate a melody by applying PWM frequency to it.
COMPONENT NEEDED
PIEZO BUZZER |
CONNECTION
For piezo buzzer, connect any of the wire to ground(GND) and the other wire to RC1.
ADDITIONAL INFORMATION
INSIDE OF PIEZO BUZZER
CODE OVERVIEW
system.h
#define A4 78
In system.h, we firstly declare each delay period value according to the musical tone chart.
unsigned int birthday[]
Assign an array for birthday[] so that it can increase 1 at the time by just simply give bithday[] a number.
E.g: birthday [4], the delay period are N which is 132.
unsigned int delay_pariod[]
Assign the delay period for each tone. The delay_period much be within 0 to 65535.
PR2 = (birthday[wait]/2);
Assign timer 2 value (PR2) with the delay period over 2 to generate the PWM period.
tone_out(birthday[wait],delay_period[wait]*20000);
Call tone_out subroutine and also assign the birthday[wait] value and delay_period times with 20000.
E.g: delay_period for C4_1 = (1) * 20000 = 20000
while(delay– > 0)
Loop forever if the 30000 is decrease by 1 at the time is still greater then 0.
pwm_set_duty_cycle(tone);
Set the duty cycle of the PWM with birthday[] value.
