RC Sumo using Maker Mini Sumo Controller
This tutorial is focusing on how to use RC Controller with Maker Mini Sumo Controller board in Sumo Robot development. Maker Mini Sumo Controller is purposely built for Autonomous Sumo Robot with Ikedo Mini Sumo Robot, but this controller also can support RC Mode.
By connecting the RC receiver to the extra GPIO ports on the Maker Mini Sumo Controller, you can turn your robot into a RC controlled robot. The best part is, it doesn't use up any existing port for sensors and this allows you to participate in both RC and autonomous categories with the same robot.
Code:
#include "CytronMakerSumo.h"
const int chA=A2;  //GPIO 01
const int chB=A3;  //GPIO 02
int ch1;  //Variables to store and display the values of each channel
int ch2;  //Variables to store and display the values of each channel
int ch1Min = 969; // read from serial monitor
int ch1Max = 1960; // read from serial monitor
int ch2Min = 966; // read from serial monitor
int ch2Max = 1957; // read from serial monitor
int offset = 15;  // Offset value for STOP function, get value from Serial Monitor
int val;
void setup() {
  MakerSumo.begin();
  // Set input pins
  pinMode(chA, INPUT);
  pinMode(chB, INPUT);
void loop() {
  // read the input channels
  ch1 = pulseIn (chA,HIGH);  //Read and store channel 1
  Serial.print ("Ch1:");  //Display text string on Serial Monitor to distinguish variables
  Serial.print (ch1);     //Print in the value of channel 1
  Serial.print ("|");
  ch2 = pulseIn (chB,HIGH);
  Serial.print ("Ch2:");
  Serial.print (ch2);
  Serial.print ("|");
  //LEFT & RIGHT
  int SpeedCh1 = map(ch1,ch1Min,ch1Max,-255,255);
  Serial.print (SpeedCh1);
  Serial.print ("|");
  //FORWARD & BACKWARD
  int SpeedCh2 = map(ch2,ch2Min,ch2Max,-255,255);
  Serial.print (SpeedCh2);
  Serial.println ("|");
  if (SpeedCh2 > offset && SpeedCh2 <= 255)
    Serial.print("FORWARD");
    Serial.print ("|");
    MakerSumo.setMotorSpeed(MOTOR_L, SpeedCh2);  // Left motor forward
    MakerSumo.setMotorSpeed(MOTOR_R, SpeedCh2);  // Right motor forward
    else if (SpeedCh2 < -offset && SpeedCh2 >= -255)
    Serial.print("BACKWARD");
    Serial.print ("|");
    MakerSumo.setMotorSpeed(MOTOR_L, SpeedCh2);  // Left motor backward
    MakerSumo.setMotorSpeed(MOTOR_R, SpeedCh2);  // Right motor backward
  else if (SpeedCh1 > offset && SpeedCh1 <= 255)
    Serial.print("Turn RIGHT");
    Serial.print ("|");
    MakerSumo.setMotorSpeed(MOTOR_L, SpeedCh1);  // Left motor forward
    MakerSumo.setMotorSpeed(MOTOR_R, -SpeedCh1);  // Right motor backward
  else if (SpeedCh1 < -offset && SpeedCh1 >= -255)
    Serial.print("Turn LEFT");
    Serial.print ("|");
    MakerSumo.setMotorSpeed(MOTOR_L, SpeedCh1);  // Left motor backward
    MakerSumo.setMotorSpeed(MOTOR_R, -SpeedCh1);  // Right motor forward
  else if (SpeedCh1 <= offset && SpeedCh1 >= -offset)
    Serial.print("STOP");
    Serial.print ("|");
    MakerSumo.setMotorSpeed(MOTOR_L, 0);  // Left motor stop
    MakerSumo.setMotorSpeed(MOTOR_R, 0);  // Right motor stop
  delay(100);
Explaination:
1. Include library
Library that we will use along this program. Need to include the library by searching Cytron Maker Sumo Library
2. Initialize Pin
We will refer to the Datasheet of Maker Mini Sumo on Arduino Pin Mapping.
3. Variable value
Variable value that will be used to check the value of each channel. The value will display through the serial monitor.
4. Minimum and Maximum value for Channel 1 and Channel 2
int ch2Min = 967; // read from serial monitor
int ch2Max = 1959; // read from serial monitor
All this value will get after running the code and see on the serial monitor display. Turn on your RC Controller and pull the channel into full throttle. You may see a different value when the throttle is changed. Put the maximum and minimum values on code based on the value you get.
Channel 1:
Right Throttle (1959-1961) - ch1Max
Left Throttle (968-970) - ch1Min
Channel 2:
Forward Throttle (1956-1958) - ch2Max
Backward Throttle (965-967) - ch1Min
5. Offset Value
Offset value is the value to set the motor stop. Due to the sensitivity and inconsistent value of the joystick, we need to set some offset to calibrate the value. This value might be lower or might be higher depending on your RC controller.
For example, the “zero” value right now is 1447-1468 (from 1 to -10) for channel 1
6. Library Use
MakerSumo.begin();
Put a “MakerSumo.begin()” to include the library for Maker Mini Sumo controller.
“Serial.begin(9600)” to display the serial monitor the value that we need for calibration
7. Input Pin
Set chA and chB as an input
8. PulseIn Function
ch2 = pulseIn (chB,HIGH);  //Read and store channel 2
pulseIn function is used to read and store the value for channel 1 and channel 2
9. Serial Reading
Serial.print ("|");
Serial.print (ch2);
Serial.print ("|");
All the value will be displayed on Serial Monitor
10. Speed Mapping
//LEFT & RIGHT
Serial.println (SpeedCh1);
Serial.print ("|");
Serial.println (SpeedCh2);
Serial.print ("|");
This syntax is use to map the value of ch1 and ch2 with pwm value (from -255 to 255)
11. Forward Function
    Serial.print ("|");
12. Backward Function
    Serial.print ("|");
13. Right Function
    Serial.print ("|");
14. Left Function
    Serial.print ("|");
15. Stop Function
    Serial.print ("|");
Related Posts
Build 1KG RC Sumo Robot using MDDRC10
This is a RC Sumo Robot based on MDDRC10 Motor Driver. The sizes are 15cm(L) x 15cm(W) with below 1kg (weight). The spec is for 1kg Sumo Robot Competition..
