RP2040/PICO
Maker UNO RP2040 Project Collection 2024
Project Collection 2024 using Maker UNO RP2040...
Water Drinking Reminder w Raspberry Pi Pico
This tutorial helps you to make a water-drinking reminder with Raspberry Pi Pico onboard the Maker Pi Pico Board using Circuitpython with Thonny IDE...
Getting Started With Maker Nano RP2040
In this simple tutorial we shall see how to get started with Maker Nano RP2040 Using Arduino IDE..
Getting Started With Maker Nano RP2040 & Blynk IoT
In this tutorial, it will focuses on getting started with Maker Nano RP2040 and Blynk IOT...
Build Fun Piano with Ultrasonic using Maker Nano RP2040
This tutorial shows how to make a piano using an ultrasonic sensor and Maker Nano RP2040. The project is super fun and very simple to make!....
Gesture Control With Maker Nano RP2040 And APDS9960
 Video Hardware PreparationFor this tutorial we will need the following components DCIM\101MEDIA\DJI_0277.JPGMaker Nano RP2040: Simplifying Pro....
Interfacing Maker Nano RP2040 With DHT22 And Sparkfun SERLCD
 Video Hardware PreparationFor this tutorial we will need the following components Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP2040....
Measure The LPG Gas Using Maker Nano RP2040 And Gas Sensor MQ-9B
 Video Hardware PreparationThe hardware setup for this tutorial is as shown below Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP2040 ....
Interfacing Maker Nano RP2040 with Grove LED Bar and Grove Slide Potentiometer
 Video Hardware PreparationThe hardware setup for this tutorial is as shown below Maker Nano RP2040: Simplifying Projects with Raspberry Pi R....
Maker Nano RP2040 Interfacing With Maker Line Using Arduino IDE
 Video Hardware PreparationSince this is a continuation from the previous tutorial the additional that we will need is the Maker Line. Maker ....
Maker Nano RP2040 Interfacing With Maker Drive Using Arduino IDE
 Video Hardware PreparationThis are the list of items used in this tutorial.Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP2040Maker Dr....
Monitor Soil Moisture With Maker Nano RP2040 And Maker Soil Moisture Sensor
 Video Hardware PreparationThis are the list of items used in this tutorial.Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP2040Grove Sh....
Measure Distance With Maker Nano RP2040 And Ultrasonic Sensor With TFT Display
 Video Hardware PreparationThis is the list of items used in the video.Maker Nano RP2040: Simplifying Projects with Raspberry Pi RP20401.44-inch 128x128 T....
