USB Serial Communication Between Arduino and Raspberry Pi
- 31 Jul 2019
- 503
Communication between 2 controllers is quite helpful. It can unlock more possibilities and also be able to do task simultaneously. Previously, I have shared how to do communication between Raspberry Pi and Arduino using I2C communication. Now, instead of using I2C, I will show you how to do it through USB cable and using serial communication. This setup also possible to program Arduino board using Raspberry Pi.
This video will show you how to do serial communication between Arduino and Raspberry Pi through USB cable.
This is the sample code used in the video for Arduino (top) and Raspberry Pi (bottom).
