-800x320.jpg)
Water Drinking Reminder w Raspberry Pi Pico
- Sharman Mudaliar
- 18 Aug 2023
- Project
- 140
Have you guys ever drink less water in a day or rarely drink water from time to time. This project will solve your problem. A project that reminds you to drink water based on the time you set according to your choice of options.
In this tutorial, We’re gonna make a water drinking reminder with Raspberry Pi Pico using CircuitPython. All we need is a Raspberry Pi Pico with a Maker Pi Pico Base.
Hardware Required
Getting Started
You can download the code here: code.py
Demo Video
You may view the demo here: https://photos.app.goo.gl/ZvGo6PupiVy39umG7
#Note: you can change the buttons with your 2 button options from these Pins: (GP20,GP21,GP22)
#Note: For the time change, make sure that your time value MUST be in SECONDS
(convert minute to seconds: Value divided by 60)
(convert hour to seconds: Value divided by 3600)
Testing: you can view the Shell monitor from thonny to see if it works. Press the start button at pin GP20 so that your monitor can show this as a result~
USB Micro B Cable
$1.48 $1.00 $1.00
Raspberry Pi Pico Microcontroller Board
$4.40++ $4.40
Raspberry Pi Pico Wireless - SMD or Pre-soldere...
$6.60++ $6.60
Maker Pi Pico & Kits: Simplifying Raspberry...
$9.00++ $9.00
