Build an Automatic Plant Watering System with REKA:BIT and micro:bit
Let's learn and build a simple automatic watering plant system using REKA:BIT. ? Press button A to get the sensor reading.
This sample program is using MakeCode. Before that you need to add the extension of "rekabit".
makecode automaticplantwatering
Join our micro:bit Malaysia Telegram Group for all your questions and discussions!
Related Posts
Build an IoT Plant Monitoring System with MicroBit and Grove WiFi Module
IoT-based Smart Farming improves the entire Agriculture system by monitoring the field in real-time. Come join me in this tutorial to learn how to keep track of your plant soil moisture with the use o..
