Ready to set sail? Learn how to build your own remote control boat using a micro:bit! Follow along with this easy-to-follow tutorial and you'll be cruising through the water in no time...
This guide will show you how to kick start your MOTION:BIT project with some guides or example code to utilize the key features of the micro:bit expansion board..
In this tutorial, we'll show you how to set up your micro:bit and Blynk app to communicate with each other, allowing you to send messages from the app to the micro:bit, which will then display them on..
Looking to add a little something extra to your micro:bit project? In this tutorial, we'll show you how to connect an OLED display to your micro:bit and display real-time temperature and humidity read..
Hi guys, today we're going to build our own oscillating table fan using a micro:bit. With the help of the micro:bit, we'll be able to program our fan..
