Reading Analog Signal Using MCP3008 On Raspberry Pi
- 14 Nov 2018
- 789
Maybe you’re not interested to write 2 different program on 2 different controller platform as shown in I2C Raspberry Pi Arduino – Reading Analog Signal. Another option, you can read the analog signals using MCP3008 (Analog to Digital – SPI) on Raspberry Pi. This tutorial will show you how.
This video shows how to read analog signals using MCP3008 on Raspberry Pi.
HARDWARE PREPARATION
- Maker pHAT
- MCP3008 - Analogue to Digital Converter
- I2C 1602 Serial LCD
- Breadboard 8.5x5.5cm
- Temperature Sensor (Celsius)
Wiring Connection
1. MCP3008
MCP3008 Pins | Connections |
1 (CH0) | Potentiometer analog signal pin |
2 (CH1) | LM35 analog signal pin |
3 (CH2) | |
4 (CH3) | |
5 (CH4) | |
6 (CH5) | |
7 (CH6) | |
8 (CH7) | |
9 (DGND) | GND (Maker pHAT) |
10 (CS/SHDN) | CE0 (Maker pHAT) |
11 (DIN) | MOSI (Maker pHAT) |
12 (DOUT) | MISO (Maker pHAT) |
13 (CLK) | SCLK (Maker pHAT) |
14 (AGND) | GND (Maker pHAT) |
15 (AREF) | 3.3V (Maker pHAT) |
16 (VDD) | 3.3V (Maker pHAT) |
2. Potentiometer
Potentiometer Pins | Connections |
1 | 3.3V (Maker pHAT) |
2 | CH0 (MCP3008) |
3 | GND (Maker pHAT) |
3. LM35
LM35 Pins | Connections |
1 | 5V (Maker pHAT) |
2 | CH1 (MCP3008) |
Software Preparation
First, you need to enable I2C and SPI module in Raspberry Pi. Then instal MCP3008 library from Adafruit. Write following command on Terminal.
sudo apt-get update
sudo apt-get install build-essential python-dev python-smbus git
git clone https://github.com/adafruit/Adafruit_Python_MCP3008.git
cd Adafruit_Python_MCP3008
sudo python setup.py install
This is the sample code to display calculated data on I2C LCD.
Thank you
References
