Build a Robotic Arm with Servo, Joystick and Arduino Maker UNO
Robot arms, which are distinct from robotic hands, are mechanical arms programmed to perform functions similar to those of a human arm. The arm can either be a standalone mechanism or part of a more complex robotic system. Let's try to create a simple robotic arm using a servo motor, controlled by a joystick.
This video will show you how to make a robotic arm using servo on Arduino.
Arduino
Thank you
SG90 Micro Servo
$1.63 $1.95 $1.63
Related Posts
I2C Communication between micro:bit and Arduino
PREREQUISITES: This tutorial assumes that you are familiar with Arduino Boards, Arduino IDE Software, Serial Monitor, micro:bit and how to download program into micro:bit.....
Raspberry Pi Pico VS Arduino UNO
Have you heard the news that the Raspberry Pi Foundation is now launching a new product named Raspberry Pi Pico? This Raspberry Pi Pico is the 1st Microcontroller Dev Board from Raspberry Pi. Wait a m..
DS18B20 Waterproof Temperature Sensor with Maker UNO
Are you trying to read liquid? temperature and don't know how?? Here is one of the ways how to get the liquid temperature using the DS1820B waterproof temperature sensor on Maker UNO.. And the reading..
Automatic Soap Dispenser Using Maker UNO
The number of people who have tested positive for Covid-19 is increasing??. One of the ways to protect us from the coronavirus is to wash our hands? regularly using soap?. So, please wash your hand fr..
Colourful Bed Lamp Using Tilt Sensor on Maker UNO
Let's try to make a colourful? bed lamp. Tilt it to get your favourite colour ?..
Display Temperature and Humidity on OLED using DHT22 and Arduino
The air is very hot and we have to take a very good care for ourself especially during haze. With this simple project, you can check the temperature, humidity and heat index...
Car Reverse Beep System Using Ultrasonic Sensor & Maker UNO
In this project I’m using an ultrasonic sensor that can precisely measure the distance to show how a beep sound come out when a car is reversed.  You will noticed that when the car is too near to t....
Installing CH340 Driver on Mac OS
Basic guide on how to install CH340 on Macbook or Mac Os related device to be used with Maker Uno..
