Getting Started with MOTION:BIT & Projects Guide
- 30 Mar 2023
- 796
MOTION:BIT is an expansion board that is designed to simplify motion control with micro:bit.
This getting started and projects guide will help you to kick start your MOTION:BIT projects with some simple guides, hardware setup or example codes including:
Note: Navigate through all the tutorials mentioned below by selecting the title from the list at the Right Hand Side of this page.
- MakeCode Extensions and Flashing the Code
- DC Motor
- Micro Servo Motor
- Li-Ion Battery and External Switch
- Maker Ports (qwiic) and GPIO Breakout
- RGB LED and Daisy Chained RGB LED
- Remote Control via Bluetooth using Smartphone
Projects:
Select the example projects from the Related Posts below
- Build an Autonomous Obstacle-avoiding Robot Car Using MOTION:BIT
- Build an RC Boat Using micro:bit
- Control Your Omni Robot Car with MOTION:BIT using Bluetooth App (COMING SOON)
- Quaruped Robot (Spider Robot) using MOTION:BIT (COMING SOON)
